book collections email follower instructable user
Murphy the Library Cat (with Secret Book Box) Assembly Instructions
Featured
Picture of Murphy the Library Cat (with Secret Book Box) Assembly Instructions
This model has not yet been published but will be this week! Please check back here for updates or follow me on Twitter for my latest announcements!
Murphy the Library Cat is a derivative of my original 3D printed cat model "Shrodinky: British Shorthair in a box":
Instructables Schrodinky docs
Unlike the Schrodinky models, Murphy is not a money box. Instead, he sits on a book which happens to be a secret box: it's lid held in place by magnets. He also wears a pair of spectacles (printed in Flex filament) and wears a shirt collar and tie. Originally, Murphy was not published and was used by me as a gift for friends and family only. However, when I took him to MRRF(Midwest Rerap Festival ), he proved very popular with many requests to make him available to the public, so I decided to do just that. Incidentally, that is where his name comes from: MRRF = Murphy.
Murphy has a choice of a plain shirt collar and standard British style school tie or a fancy collar with a bow tie. Due to the way these are designed, the collars and ties are not interchangeable.
Murphy is available in both single and multi material versions. this way, nobody has to miss out
Fully assembled, he is 250mm tall
The largest model in the Murphy assembly is the cat body, the dimensions are:
length: 109mm, width: 138mm, height: 160mm
If your printer can accommodate this then you are good to go!
Step 1: IMPORTANT MODEL INFORMATION - PLEASE READ!!
Picture of IMPORTANT MODEL INFORMATION - PLEASE READ!!
Murphy is a 3D printed multi part assembly and is available in multi and single extrusion versions (although to be fair, the only parts of him that use multi material extrusion are his head and the pages of the book).
He will be available for purchase on MyMiniFactory and Cults3D in the following packages:
  • Murphy the Library Cat: The complete package
    This includes the following:
    All the common files used by both versions of the model:
    Cat body with tie
    Cat body no tie
    Book base and spine
    Book cover
    Bow tie
    Bow tie shirt collar
    Standard tie
    Standard shirt collar
    Spectacles
    Collar peg
    Eye base
    The files for single material extrusion version
    Cat head single extrusion
    Book pages, foil and binding
    Eye pupil single extrusion
    The files for multi material extrusion
    Book pages
    Book Binding
    Book foil
    Eye pupil
    Cat head
    Cat head inner ears
    Cat nose
    If you get this package then you will not need to purchase any others. It includes ALL the Murphy files.
  • Murphy the Library Cat: Single Material Extrusion Only
    Cat body with tie
    Cat body no tie
    Book base and spine
    Book cover
    Bow tie
    Standard tie
    Spectacles
    Collar peg
    Eye base
    The files for single material extrusion:
    Get this package if you have a printer only capable of single material extrusion. It does NOT include any files for multi material extrusion.You will need to purchase these separately.
  • Murphy the Library Cat: Multi Extrusion "Top Up"
    The files for multi material extrusion only
    Book pages
    Book Binding
    Book foil
    Eye pupil
    Cat head
    Cat head inner ears
    Cat nose
    Get this package if you have bought the single material extrusion package and then decide you want to print the multi material extrusion model parts too.
    Please note, you will NOT be able to print a complete Murphy model with this package. You will need to purchase the single extrusion package in addition to get the common files.
MODEL MATERIAL INFORMATION
Murphy can be printed in a variety of materials providing they can be glued together. However, I would strongly recommend that his spectacles are printed a flexible material(there are a variety of these available now). The spectacles are a delicate model and the flexible material makes them durable. They are not glued in and pinch into the fittings on his nose. As a result, they can be removed easily for packing (if you want to send a print to someone) and easily replaced if they are lost. Glued in standard PLA and other materials are more prone to breaking and damage in this instance.
Very little flexible material is used so a sample packet (available from most sellers) should suffice
ADDITIONAL ITEMS
To make Murphy you need a couple of items to complete the model:
  • 4 x magnets(18mm diameter 2mm thickness) you may use smaller but not larger
  • Quick and clear drying glue capable of bonding the material you are printing in.
    (This document assumes you have read and are following the manufacturer's instructions)
  • Elastic bands (very useful for holding things in place whilst glue is drying)
OPTIONAL ITEMS
Should you wish to add whiskers to Murphy you will need to the following
  • Fishing line for his whiskers (12lb fishing line if printing to scale)
  • Scissors
Cats are cool. This is cool. I look forward to the next instructable.
This is super impressive! Thanks for sharing your process!
Loubie3D (author)  audreyobscura11 days ago
Thank you! I have so much fun designing these models, it's always gratifying to find others enjoy them.
